Rebuilding my D60, advice needed.
I am rebuilding my D60 front end on my 97 F350. I have it all disassembled, and cleaned. I need some advice putting it back together...Shims where mostly destroyed during bearing removal. All the info, that I have seen, and my Spicer book, shows the shims between the diff bearings, and the diff for backlash. Behind the inner pinion bearing outer race, for pininon dept. And also behind the outer race of the outer pinion bearing for preload.
My first question, what would be a good starting point for pinion depth? Shimming in all of these places seems to be a pain. It will involve pressing on and removing bearings multiple times, and races on the pinion?
Anybody have any tricks up their sleeve?
They are real close. I mic'd them for total thickness, and Diameter. With .001. I have a game plan now. I will take pics as I am going along. If anybody sees something dumb, hand slap! So, I'll do it right! lol
Surface rust!
More rust!
Diff case had lots of coffee creamer in it. I think the previos owner took it under water, then never checked the diff, or used it again. All the rust is on one side of everything. My plan is to bust it apart, clean it all up with a brass whhel, then reassemble. Ring gear should be good? Right?
Dana 60 diagram.pdf
Dana 60 Parts list.pdf
dana 60 Build parts 610610.pdf
These pages are straight out of the Dana book. I have the part in question highlighted. Any ideas? I know somebody has had to run into this before.
