Manual transmissions
Old 06-29-2016, 02:29 PM
cliffordingles's Avatar
cliffordingles
cliffordingles is offline
So the search function for the site doesnt work with my phone. I am wondering which tranny i have. The truck is an 85 f250 4x4. It is a 4 speed with granny first. I can post pictures later if needed. Thanks!
Old 06-29-2016, 02:41 PM
Festus Hagen's Avatar
Festus Hagen
Festus Hagen is offline
Methanoholic
T18
-Enjoy
fh : )_~
Old 06-29-2016, 03:29 PM
FuzzFace2's Avatar
FuzzFace2
FuzzFace2 is offline
Received 2,085 Likes on 1,778 Posts
The other thing that can help you is this link from Gary
Certification Label - ???Gary's Garagemahal
Dave ----
Old 06-29-2016, 04:45 PM
redbayredneck's Avatar
redbayredneck
redbayredneck is offline
My 86 F250 had a new process 4-speed in it.
Only way to know for sure is to crawl under the truck and look.
Old 06-29-2016, 06:33 PM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
Originally Posted by cliffordingles
I am wondering which tranny i have. The truck is an 85 F250 4x4.
This bit of info narrows it down to 3 different 4 speeds!
TRANS code printed on the Certification Label, glued to the left door face.
It could be any of the following: A = New Process 435 4 Speed / F = Borg Warner T-18 4 Speed / P = Borg Warner T-19 4 Speed.
T-18/T-19 = The shift lever retainer cap (8MTH-7220) threads off/on.
New Process 435: The shift lever retainer cap (B8T-7220-D) has two notches, is retained to the shift tower with two pins.
This cap must be pressed down by hand and held down while turning it counterclockwise to remove it.
Some unknowing people use pliers to remove it, which tears out one or both of the notches. Not pleasant!
Old 06-29-2016, 11:42 PM
cliffordingles
Thank you for all the replys!!!
trapperjack
01-06-2016 12:29 AM
Engalwood
01-24-2012 10:00 AM
douglpr42
07-18-2010 05:01 PM
97F250LD4X
08-29-2007 10:05 AM
Eddielee
07-08-2007 03:11 PM
Quick Reply: Manual transmissions
