Broken therostat housing bolts
Get a large washer like a fender washer and have the hole the same diameter as the bolt. Weld that sucker on (MIG is fine, no reason for TIG), then weld a large nut on the washer (reason for fender washer). When that cools give a turn, slowly back and forth. This trick works almost every time. I can't remember last time we tried using EZ out.
If you can get the broken bolts out, I recommend using studs. Even if you have to cut the threads off of bolts, those stupid bolts on that housing are a pain. Thread studs into the water pump with a little JB, and let it set up. Then use nuts and lock washers on top, and never worry about bolts sticking in there again.
__________________
'96 7.3 F-350 Reg Cab 4x4 - bought new.
'04 6.0 E-350 custom 4x4
'08 6.4 F-550 Reg Cab 6 spd 4x4
'17 6.7 F-250 KR ccsb 4x4
Yea I honestly have no clue what the f**k I'm gonna do now don't have a welder, ac pump bolts won't come out so I have no damn room, no cloolant in the truck no tail lights or bed so I can't get it to a shop, I'm running out of options I might just rtv the **** out of it and throw 2 bolts in and hope for the best at this point I'm loosing my patients
