clutch
clutch
I have a 95 ford ranger xlt 2.3 5 spd 177k miles on it.
recently put new clutch slave cyl , and clutch master cyl on it. Problem is sometimes clutch pedal has no play in it , other times it has at least half the pedal. I have bled at least two pint cans of fluid thru it, doesn't seem to have any air in the lines. Help !! don't know what to do from here, any ideas.
clutch
Wanna join my lynching party for the engineer who chose and designed the hydraulic clutch system?
Mine is just almost able to disengage so I lightly grind into reverse but it wont creep.
And I need to be in first before stoping or it wont go into any gear lower than 3rd!
But if I have sombody step on the clutch climb under and I shove a socket in there to heep the lever from returning, you pull the pedal up and it works fine when I next step on it, but just that once!
And I bled the system several times and hear and see no air at all!
W T F ???
W T F ???
clutch
Shifting on the fly is no problem even without the clutch, just wait for the input and output shafts to match speed as the engine decelerates, pushing lightly for it to go into the next gear, and it will slip into gear like a class "A" tranny does.
I have had so many crapy vehicles in my life, I just call it practice.
clutch
I went to check the linkage adjustment and found the linkage from the lever to the master cylinder was worn and wallowed out big time!
It was causing way too much slack in the linkage.
I took it appart and welded it up, re ground/drilled it to fit and the clutch works now!
Econo4spd
06-24-2014 01:45 PM
Wild Karrde
08-13-2007 10:05 AM
