Aftermarket Radio
Aftermarket Radio
For my 88 BRII I'm in the process of installing an aftermarket radio. The existing wiring harness was a mess, all hacked up for a pre-existing amp and subwoofers. So I've removed the old wiring harness and splicing it directly to the wires from the new head unit. I've got all the speaker wires figured out.
Now I'm having a hard time figuring out the correct power combination. I've got it to work in 2 different scenarios, but both options do not automatically turn the radio off when I turn the car off and remove the key. Also the radio can be turned on with inserting the key.
Setup 1 (works but always on)
Green/Yellow = 12v constant goes to Yellow (memory)
Yellow/Black = 12v accessory goes to Red (accessory)
Orange/Black = ??? goes to Yellow (memory)
Blue/Red = illumination goes to nothing
Setup 2 (works but always on)
Yellow/Black = 12v accessory goes to Yellow (memory)
Orange/Black = ??? goes to Red (accessory)
Setup 3 (doesn't work at all)
If I remove Orange/Black from any scenario nothing works.
So my question is... What is Orange/Black and why can't I find it listed in any wiring diagrams for 88 BII or 88 Ranger? What other combination can I try to get the radio to turn off when the ignition is off and key is removed?
Blue/Red is always hot 12v.
Yellow/Black is on when the ignition is on 12v.
Orange/Black has a very small voltage of .02v when the vehicle is on.
You would think I could just leave Orange Black out of this configuration and call it a day, but that doesn't see to be the case. I wonder if orange/black could potentially connect to chassis. I haven't tried that yet.
You're right, wire nuts are only there till I figure out which of these wires goes where. I've used Posi-twist on all the wires that I know connect where they're supposed to.
So leaving the Orange/Black connected with Green/Yellow on radio memory completely drained my brand new battery in about 2 weeks. Had to jump start the engine this morning.
For now I've capped the Orange/Black but I'm left with a non-functioning radio.
One thing I did notice was the last time I went to put my headlights on the speakers made a pop sound and the radio turned off. This leads me to believe Orange/Black deals with illumination, but I thought that's what Light Blue/Red was used for.
Davetruck
06-21-2015 04:18 AM
fordka
10-12-2014 05:24 PM
tzanaglio
06-24-2011 08:38 AM
diesel demond
05-17-2003 09:28 AM
