PCM/ECM Compatibility
Most chips I have seen disable it or are not compatible with PATS. You know that much at least, you also have a GH so I imagine your Theft light flashes for a bit on start up.
I don't believe they're compatible right off the bat, you may need to get the chip burned to compensate for some things. Honestly you'd be better off talking to Larz or Matt at GH and see what they say since you're running their setup.
If you're running a Gearhead chip, it by passes the PATS and overrides what's on the PCM and tells it: "You're now PMT1 instead of EDM2".
I've run a PMT2 PCM on my Excursion, the ONLY problem was that it wasn't from a California Super Duty, so it had no clue what to do with a GPCM and was looking for a glow plug relay instead. This lead to hard starts during the winter until I replaced the PCM with the EDM2 PCM I originally had.
Riverboy460
12-31-2013 11:22 PM
broncxl302
02-13-2012 11:55 AM
