Coolant Gauge Issue
Coolant Gauge Issue
A ways back I installed a Borg Warner coolant sender for my IPC coolant gauge. Since my last thermostat install a few months back the gauge needle never gets to the 'N' on the NORMAL scale of the gauge. It gets close when on a 100* day with the A/C on MAX but it usually sits midway between the lowest setting and just shy of 'N' on the gauge.
Now, I've already performed the test where you unplug the sensor and then ground the signal wire. The needle went from one extreme to the next, indicating the gauge is working correctly, as are the wires to it. Do I have a defective sender or should I just get a different brand?
That's where my stock gauge always stays, just before the N and occasionally gets to the O idling in traffic on really hot days with the A/C running. This past weekend I installed an aftermarket water temp gauge in the dash and installed the new sender in the factory location and was surprised to see how hot the motor is really running. I run a 170* Tstat and was thinking being so low on the factory gauge that I was at 180* at the most. The new analog gauge shows the actual temp is 190 to 195. From what I've read, a Tstat starts opening at it's advertised temp but isn't fully open until 20* higher, which means mine isn't fully open until 190* which corresponds to the new gauge.
Well, like I said, my running temp with the 170 stat is 190 to 195. I have to believe with a 195 stat my temps would be over 210 and I don't want that.
thordehr
05-07-2012 04:39 PM
tommyl
02-22-2012 08:09 PM
tjbeggs
18
08-31-2007 01:43 PM
