Part numbers for 300 water pump pulley
Old 06-27-2016, 11:01 AM
kydavison's Avatar
kydavison
kydavison is offline
Does anybody have part numbers for water pump pulleys that were used on the 300? I'd be interested for model year 1977. There were two different water pumps used in 1977 and the pulley I have will not work with the Flowkooler pump I just bought. My pump casting is marked D2TE-8505-AA but I need the pulley used with the other pump. Thanks!
Old 06-27-2016, 01:13 PM
kydavison's Avatar
kydavison
The aluminum hi-flow water pump is 3/4" shallower than the pump I took off. The pulley I need would have to be 3/4" shallower so it doesn't hit the outlet of the hi-flow pump. The hi-flow pump has a shaft diameter of 5/8" versus 3/4" on the old pump.
Old 07-03-2016, 01:05 PM
ZarK-eh's Avatar
ZarK-eh
ZarK-eh is offline
Can a Spacer be used to with the original pulley?
Old 07-03-2016, 05:15 PM
kydavison's Avatar
kydavison
I thought about a spacer but I think the bearings might wear out quicker with that overhanging weight. I'm going to see if I can cut the stock pulley down 3/4" and move the radiator towards the fan with some spacers.
Old 07-29-2016, 06:44 PM
ultraranger's Avatar
ultraranger
ultraranger is offline
There are two different water pump shaft lengths for the 240/300 engines. I ran into this when I installed a Ford C-2 power steering pump from an '82 Bullnose onto my '69 F100 Ranger.
My original water pump pulley only had one groove (sheave) on it. The water pump pulley I took from the Bullnose 300 had 3 grooves. When I went to put the 3 groove pulley on my '69 water pump, the 3 groove pulley bottomed out against the pump housing so the pulley wouldn't bolt up.
After some research, I found there was a shorter 3-5/8" length water pump and a longer 4-5/16" water pump. I bought a new 4-5/16" water pump from NAPA and swapped the pumps out. It's a Tru-Flow brand p/n 42070 (less than $40.00 bucks).
Photos of my installation in the following link.
https://www.ford-trucks.com/forums/1...l#post14794861
Old 07-29-2016, 07:48 PM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
Old 08-01-2016, 05:30 PM
kydavison's Avatar
kydavison
Ultraranger - I found your write-up after I discovered my problem. My stock water pump pulley has two grooves that both drive the alternator. I bought another pulley that I'll either modify to shorten or just cut one sheave off and drive the alternator with one belt - the width of the sheave is the difference I need to fit. Not sure which route I'll take yet. The Flowkooler pump only comes in the shirt shaft so I have to work around that.
Old 09-21-2016, 03:39 PM
Sam's1967's Avatar
Sam's1967
Sam's1967 is offline
UR, hope you are well. I have some play in my water pump and I am going to change it. I went to my local Autozone and they only list one pump for my 67. If I recall correctly, I have a 3 sheave water pump pulley. Any suggestions or should I simply remove the water pump, measure and see if the one at the Autozone is a match.
I believe that this may be the reason (play in the water pump) why I am getting some squeal with my a/c set up.
Old 09-27-2016, 12:56 AM
Sam's1967's Avatar
Sam's1967
Replaced the water pump with a Duralast model. Appears similar to the smaller pump in the previous post. No longer have any play but still have some squeal in the compressor belt. I am going to replace the a/c bracket with the early 80's type and see if this solves my problem or adds to it.
Old 08-15-2020, 06:47 PM
Kristopher Brock's Avatar
Kristopher Brock
Kristopher Brock is offline
i have the same problem? did you get it fixed and how?
Old 08-16-2020, 03:47 AM
kydavison's Avatar
kydavison
I never fixed my situation. Still have the high flow pump sitting on the shelf.
1985highboy
Large Truck
11-04-2017 03:58 PM
Jasonnoel
30
03-14-2013 10:28 PM
fourby4
02-06-2011 02:59 PM
g0dl355
11-15-2009 06:38 PM
No_Joke
12-30-2002 11:54 PM
Quick Reply: Part numbers for 300 water pump pulley
