Glow plugs
Glow plugs
Hey all!
My glow plugs are slowly dying on me. I managed to get through the winter with the plan to change them out when the weather was more favorable.
I've watched and read quite a lot on doing the job and feel pretty comfortable doing it but knowing what needs to be done to get to the plugs I was wondering if there was anything I should do while in there and have so much taken out.
A little history on my truck, its pretty much stock with a PHP Phoenix tuner.
I have an Edge insight and an EGT sensor, and a modified air intake ( I forget which one I have but it is similar to the 6637 only the filter is reusable). I think that is about it, the truck has 230000 on it and runs really well other than the hard starts in the winter and the related check engine light and codes.
I'm not looking to do anything crazy in there just some preventative maintenance and standard upgrades.
Any and all input is appreciated!
I would inspect your UVCH's while you are in there, and do the "50 cent mod". Also a good time to change your CAC boots if your existing ones are looking like they have seen better days. Inspect your turbo wheel, re-torque your injectors and your rockers at the very least, maybe even pull the injectors and change the external O-rings (use only Alliant o-rings, Riff Raff sells them). Check your cups also if you pull the injectors, make sure none are cracked. You could let it idle and watch your oil ports in the injectors too. This will be a brief visual inspection on your injectors to make sure the oil side of them is operating correctly.
Perfectly fine, no time limit, just make sure nothing can get in there or your open intake plenums or the open turbo, the last one will make a mess of anything that inadvertently gets sucked in! (No need to reinstall the CAC tubes and everything for this if you hadn't picked up on that.)
The oil ports direct the oil from the injectors back to the head. You should see a healthy squirt of oil from each one as it operates.
Ok I did it and it went very well! Wow is that passenger side a lot harder than the drivers side. Anyway I cleaned everything as I went so looks awesome under there now.
I did have to replace the Crankcase air filter gaskets and the next time I have the valve covers off I will replace the drivers side as it was pretty corroded.
Its all back together now and running fine but....I'm still getting the same trouble codes, P0676 and P0674 which is why I did the glow plug job to begin with. I know I should have investigated more first but I figured that with 240k miles and having replaced the GPCM last spring it was a no brainer.
Now I need help figuring out what those codes really mean.
