1989 f250 dually
You could of gotten a f250 in either 3.55 or 4.10
The tag in the door says it came with 3.55 (code 39), but I wonder if whoever swapped for the dually may not have changed the front gears and that may be why the front end is stripped out now. I could not find an id tag on the front. I guess I will have to take it apart to see what is in it.
on
i couldn't find 3.55 in the 93+ pickup drw axles.is why i used a first gen/short yoke.
on
Brad once informed me that the front d50 carrier swaps right out just like a ford 9" rear.pull the axles,swap the whole setup center sections and slide your axles back in.so that's the easiest and most affordable by far.
you could go with a d60 swap but it's overkill if you don't race off road,want a lift and run big tires.
the other bad thing about the d60 is,that it sits higher,so you need to lift the rear up too.this isn't what you want if you load your bed with heavy items by hand.
if you've got a spare grand itching in your pocket (id recommend investing it instead) and you just gotta have a d60,then now's the time i suppose.
you need the front springs,new u-bolts,the axle itself,the rear f350 4wd spring block and new u-bolts for the rear.
is the front drive shaft a different length too? probably.if so,you'll need that.
oh.pitman arm is different too.swap that for increased turning radius.then what? you gunna run the old ball joints and u-joints in the used axle? i doubt it.so that grand turns into 1500 before your done.then what did you really gain? did you spend the coin for something you really can make use of or was it really just poor spending? just because it's "better" than the tbb,doesn't mean the ttb isn't more than good enough for most of what most of us will ever do.
this is why i'll never swap in a d60 front axle in mine.if this helps any,cool.
