New camber bushings?
Not the best analogy but those are the same principle as shims. They come in different degrees depending on how much your caster and camber needs to be adjusted. They are different due to the left and right side of your axle needing different bushings due, I guess, to manufacturing tolerances. You shouldn't just arbitrarily replace them until you know what your caster and camber is and whether or not those bushings are still the correct ones. When you're done with the D60 rebuild you should probably take your truck to a competent alignment shop to see if the bushings need changing. Ask around and try to find one that works on trucks.
If you're a serious DIY'er you can buy caster and camber gauges for around $200 and check it yourself.
sandymane
10-06-2017 07:20 PM
JonathanN
04-03-2012 02:40 PM
gotdiesel
08-06-2004 12:08 PM
