Can't Leave Well Enough Alone !!
06-26-2016, 08:21 AM
I have stock 15X7 chrome wheels with '55 Ford center caps on my '84 F-150 2WD. Tires are Dayton Timberline 30X9.50 R-15..I found some new wheels, but the nearest size available is 16X8. Obviously I would need new tires.."The Daytons have 3,000 miles..but are 7 years old...Would the 16X8 wheels be a problem ?..thanks..jv..
06-26-2016, 08:30 AM
Backspacing and the size of your new tires is the question that needs an answer.
The way I see it only if you cant get a tire that is 30" tall as the speedo will then be off.
Dave ----
06-26-2016, 08:35 AM
Backspacing is not a problem..So, if the new tires are about 30 inches, I should be OK..I don't care about the speedo. Hell, I never drive over 50 anyway!!
06-26-2016, 02:09 PM
If the speedo is a problem, Jerry, pull the speedo cable, determine what tooth-count the gear has and get one with 1 fewer teeth.
06-26-2016, 07:38 PM
I'd be very interested in those 15X7 chrome wheels with '55 Ford center caps should You want to part with them.
06-27-2016, 07:27 AM
Got an Email from Rocket...Can't order wheels. 6-8 week backorder. ?? I'll post if I sell the chrome 15s..
06-27-2016, 07:58 AM
William
2015 - 2020 F150
16
08-08-2017 10:27 PM
captaincody
1999 to 2016 Super Duty
10-17-2011 12:14 AM
03f150man
10-30-2003 08:44 PM
2000Expy
07-15-2003 09:30 PM
usmccowboy
04-12-2003 05:29 AM
