1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Northern tool spin on filter, now with installs
Old 07-16-2016, 09:56 PM
SuperDutyScaler's Avatar
SuperDutyScaler
SuperDutyScaler is offline
Yes my new pioneer head unit has usb and auxiliary ports in the rear which is the reason I installed the plug in the little cubby hole. My head unit will also "connect" through the USB to my new galaxy S7 and virtually turn the touch screen on the head unit into my phones screen, so whatever my phone can do I'll be able to use the touch screen on the radio to control and see whatever it may be. Kinda excited to use the Google maps while driving and have it on the radio screen and hear directions through my speakers in the truck
  #47
Old 07-16-2016, 10:02 PM
SuperDutyScaler
And I half installed my trans today, just a word of advice DON'T TRY THIS ALONE! It took me from 10:30 this morning till 615 tonight to get the trans bolted in, crossmemeber in, shifter cable properly adjusted and back in, harness connected, tease mounted, and driveshafts back in. I still have to fill the trans and tcase install my 6.0 trans cooler and mount the spin on filter and temporary use the original hard lines for the filter. I bought -AN fittings that connect directly to the tranmission in/output cooler holes and I'm going to buy Earls fittings and hose and run a real nice clean setup this coming week. After seeing the way it will be using hard line then fittings to rubber trans line and then back to Steel line just turned my stomach and seeing his good using -AN fittings and braided Earls hose I ordered a bunch of stuff from Jegs.com
  #48
Old 07-16-2016, 11:55 PM
SDSC4X4's Avatar
SDSC4X4
SDSC4X4 is offline
"Kinda excited to use the Google maps while driving and have it on the radio screen and hear directions through my speakers in the truck "
That would be my main reason for the installation! Sounds like the installation will be super sharp, too.
  #49
Old 07-17-2016, 08:01 AM
SuperDutyScaler
Well that and having a backup camera now...and a HD screen so the kids can watch movies while were going places...and the ability to have my phone on the radio screen is kinda cool LOL
  #50
Old 07-17-2016, 08:18 AM
SDSC4X4's Avatar
SDSC4X4
SDSC4X4 is offline
...and we have a new electronics expert on the forum!
  #51
Old 07-17-2016, 10:41 AM
SuperDutyScaler
Lol no i just want some modern. Will say I just spent an hour messing with the radio and phone and it's AMAZING. plus my JL speakers and dynamate doors SOUND AMAZING NOW
  #52
Old 07-17-2016, 10:47 AM
SuperDutyScaler
http://m.ebay.com/itm/231085035315?_mwBanner=1
Just bought these so I can run Earls fittings and braided hose for the cooler lines, after looking at the ugly Steel line and then this nice new spin on filter and 26row cooler I have to make it look good
  #53
Old 07-17-2016, 03:02 PM
SuperDutyScaler
I can't find 1/2" trans line local so can I use regular 1/2" heater hose till Wednesday or Thursday when my Earls hose and fittings show up?
  #54
Old 07-17-2016, 05:17 PM
MisterCMK's Avatar
MisterCMK
MisterCMK is offline
Why don't you just wait until the braided stuff is in? The braided fittings don't work with heater hose.
  #55
Old 07-17-2016, 08:48 PM
SuperDutyScaler
I just wanted everything hooked up and running so I could check it all out before my vacation week. But I got annoyed and packed it in and I'll just wait for the stuff. Did tinker with the new radio and I can't get it to Bluetooth or mirrorlink for some reason! Starting to remember why I like being "old school" and keeping old simple reliable technology
  #56
Old 07-17-2016, 08:56 PM
MisterCMK's Avatar
MisterCMK
AN stuff gets expensive depending on what fittings you use. The -10 stuff for the breather setup on my Mustang was $150 for just the hose and hose ends. And that is only from each valve cover to the catch can on the firewall.
  #57
Old 07-17-2016, 09:10 PM
Bigpipes 35's Avatar
Bigpipes 35
Bigpipes 35 is offline
I wouldn't use heater hose but fuel line should be fine...
  #58
Old 07-18-2016, 11:56 AM
SuperDutyScaler
I only ordered some stuff and I figured I could use the stock lines for the rest. But after mounting the filter where I wanted and deciding I'm ditching the stock stuff I might just order reverse flare fittings with hose clamp ends and just run rubber trans hose and install wire loom protector over it. Fittings are 2 bucks a piece and hose at the mom and pop store is w.50 a foot for 1/2" inch so it will be like thirty bucks to run it I assume
  #59
Old 07-18-2016, 12:23 PM
SuperDutyScaler
After searching the innerWeb and seen hydralic fittings are inverted flare and they sell 3/8 and 1/2 inch online I called the local hydralic shop in town. And what you the guy told me they have all kinds of fittings in stock and he could even make me fittings with low pressure hose attached so I can hook directly to the trans cooler! So now I'm gonna stop after work and get prices for hoses if not I'll just buy fittings and get regular trans line from the mom and pop store
  #60
Old 07-18-2016, 06:37 PM
hav24wheel's Avatar
hav24wheel
hav24wheel is offline
I like using push lock hose and fittings personally. The push lock hose can be used with regular barb fittings and a hose clamp too, and the stuff holds very nice!
Quick Reply: Northern tool spin on filter, now with installs
