Help needed starting my truck?
#33
your year truck the controller does not (see ) the heated glow plugs like the later year trucks do.. your wait to start light is not a indicator of heating the glows...you have no power to the glows or they are all burned out...there is two circuit's of power to the glows one for the low current controller and one high current, to heat the glows...if your glows were heating it would blow off your air cleaner...the high current comes from the start solenoid and is switched buy the glow plug relay that is switched buy the controller, this system has a fault....or it would start....as we know, the engine runs...
#35
Received 3,102 Likes
on
#36
As said, still risky. If it gets into the chambers where it needs to be, and the glow plugs are working, the glow plugs will ignite the starting fluid.
#39
your glows are not working....and you are not listening... and its still broken, and your complaining and you don't understand, we are trying to help you...just because the timer in the controller is working, and the wait to start lite is on...that doesn't mean the glows are getting hot. you must verify that you have a good connection, one that will flow 30 amps, to the high current connection on the glow relay...read the stickys at the top of the page.....
#40
on
#42
on
ok. just checking, because you said they were good, or they were working, but you never actually said they were getting power.
i have seen way to many times where people claim the plugs were good and working but when they finally check for power they come back with their tail between their legs and admit there was no power out of the relay.
#43
#44
#45
on
Do you have a volt meter?
If you do ...
Set it up for 12v DC (unless it's auto ranging)
Connect the Red+ lead to the positive battery post.
Connect the Black- lead to a glow plug connector without removing it from the glow plug. (Slip the connector up a little)
Have a helper turn on the key, While the Glow Plugs are active take note of the voltage.
Post the voltage.
-Enjoy
fh : )_~
If you do ...
Post the voltage.
-Enjoy
fh : )_~
norm805
02-03-2019 06:45 AM
Flying Finn
18
10-29-2009 01:34 PM
