Need advice
#166
It is a black/light green, as shown here: Tachometers - ???Gary's Garagemahal. And the other end of the wire is here: Fuel Tank Selector & Gauges - ???Gary's Garagemahal.
#167
#168
My mistake - the wire you are looking for is the dark green/yellow wire. That is the tach signal from the ignition. The black/light green is a ground that tells the tach the engine is an 8 cylinder as without the ground the tach is in 6 cylinder mode.
But, all factory harnesses have the dark green/yellow wire.
#169
Ordered more parts today:
Carb
2 gas tanks
1 sending unit
radiator
Fuel pump
air cleaner
9mm ford racing wires with holders. Already have the intake, distributor with coil, lokar throttle cable and lokar C6 kickdown cable. Gasket set for intake. Next week there won't be any reason for excuses to not have this thing running. I'll buy all the hoses, water pump, and small items locally. I tried to purchase most of these items locally but no one could even come close to the online pricing especially with free shipping.
Carb
2 gas tanks
1 sending unit
radiator
Fuel pump
air cleaner
#171
#172
#173
Gary put me onto 1A Auto : Aftermarket Auto Parts, Car Body Parts, Replacement & New Automobile and Truck Parts | Buy Discount Car & Auto Parts Online for the senders & tank straps
for my 81 F100.
That was after I asked if the 16 gal & 19 gal side tanks used the same senders - no they do not.
Dave ----
#175
Where did you come up with TNKFG34C? Can you find the Ford part number on my site: Fuel Senders & Pumps - ???Gary's Garagemahal
#176
new-aftermarket-spectra-premium-fuel-sending-unit-tnkfg34c
#177
#178
#179
#180
