Need advice
Chris - Our trucks have electrically-operated valves, but the later systems were controlled by pressure from the in-tank pumps, which were controlled by the tank switch. Look at Page 104 using your link, and you'll see the switch just controls the in-tank pumps and determines which fuel level sender gets connected to the gauge.
OK on the rest, thank you for the correction!
Gonna talk to myself here, as an opportunity to put up some pictures from the belts-n-hoses project.... 1996 Ford Bronco 351W roller
An antifeeze leak I thought I'd chase:
But notice how high up off the manifold the hold-down bolt is:
That's because the bolt is broken!
Which looks like this when mostly drilled out
And you invariably end up doing this:
Here are some pictures finally....
The only thing I was able to find when I went to the junkyard Sat was a fuel door.
After looking at these pictures I am starting to wonder if it's worth it!!! Looks worse than in person.
This is the EGR stuff I was talking about that came apart.
I found this under the dash mid way but more towards the pass side.....Is this the Inertia switch??
Since I went out and took the pictures and all was quiet other than the buzzing from the key in the ignition.....I turned the key to run and I think I hear the faint hum of the high pressure fuel pump. I will get someone to turn the key on again when I am under it to make sure that it in fact is running. Now if it is in fact running does that mean I need to start at the tank selector switch to see if it is getting power and then sending power out from the switch to each tank pump and then go there and check? I am asking this before I go back to the wiring schematic.
#30
