Gem module
Old 06-24-2016, 06:39 PM
Wrecking ball's Avatar
Wrecking ball
Wrecking ball is offline
Gem module
Where do I find the gem module
Old 06-24-2016, 07:08 PM
163junk's Avatar
163junk
163junk is offline
Need a little more info, like what year, model etc.
Old 06-24-2016, 07:17 PM
AllaboutMPG's Avatar
AllaboutMPG
AllaboutMPG is offline
I don't think a 2003 F250 has a Gem. Ford changed it to a different module of some kind somebody will be along shortly and refresh our memory as to what it is
Old 06-24-2016, 07:27 PM
Wrecking ball
Sorry I have a 2002 f250 7.3l diesel.
My problem is that when it rains, it leaks through my windshield and gets all into my electrical. My truck starts to stall and shorts out.
After I posted this question, i did more research and found this year doesn't have a gem module but has a VSM(vehicle security module).. Can anyone tell me more about it because i am not finding any information
Old 06-24-2016, 07:34 PM
163junk's Avatar
163junk
163junk is offline
Sounds more like your IDM is getting wet, does it drop to 4 cyl before it dies? Ive had a few F450's do that to me.
Old 06-24-2016, 07:41 PM
Wrecking ball
I am sorry @163junk I can't answer that question I am asking for my husband and he currently isnt home
Old 06-27-2016, 02:03 PM
retiredsparky's Avatar
retiredsparky
retiredsparky is offline
This thread does beg the question: How about getting estimates for a windshield remove/re-install with new sealant? That solves the wet carpet/wet whatever module/engine not running. Windshield work is most often a lot cheaper than replacing a module.
Larry
Old 06-27-2016, 03:32 PM
HKusp's Avatar
HKusp
HKusp is offline
What he said^^^^
Old 06-27-2016, 04:46 PM
Pikachu's Avatar
Pikachu
Pikachu is offline
It would probably be worth it to just have the windshield replaced, especially if it has the typical wiper scratches, nicks, chips, sandblasting, etc. that happens over the miles.
Old 06-27-2016, 05:29 PM
Jaime74656's Avatar
Jaime74656
Jaime74656 is offline
IF for some reason there is a GEM module, it will typically be where the fuse box is or close by in the cab (and the door chime would be part of it, as least in the Mustang I have that is how it is) but I am pretty certain that Ford switched to GEM modules around 2004 maybe 2003.5 if at all...but again I have seen strangerthings too...
Also get the windscreen replaced/resealed so you can fix the wet model/carpet/electronics problems
Old 06-27-2016, 05:43 PM
HKusp's Avatar
HKusp
HKusp is offline
The GEM and VSS are located behind the radio center of the dash Jaime.
Old 06-27-2016, 06:52 PM
Jaime74656's Avatar
Jaime74656
Ok cool, I kinda was not entirely sure, thanks for that info
Old 07-23-2021, 01:25 PM
sotxmandi's Avatar
sotxmandi
sotxmandi is offline
Help anybody... somebody
1999 F250 crew cab 6.8 V10. 250k miles
typical GEM issues, replaced GEM, wiper motor, worked like a champ for 5 min. Blew the GEM in the same area.... any help would be awesome (bottom left corner jus above the screw in pic)
Old 07-24-2021, 07:03 AM
Sous's Avatar
Sous
Sous is online now
Received 4,459 Likes on 2,849 Posts
Solely based on your brief description of the issue above, I would suspect a fault external to the GEM. Possibly in the wiper motor circuit because that is the area you specifically identified.
What are your symptoms other than two burnt GEM's?
Did the symptoms pop up out of nowhere or was there work done prior to or during?
Where did you get the GEM?
Is it exactly the same code as the one you replaced?
Anything else you can tell us?
Old 07-24-2021, 02:08 PM
sotxmandi's Avatar
sotxmandi
Cardone GEM purchased at Auto Zone. It’s the right one I checked cause they sent me the wrong one first and it had more problems than this one.. Burns in same spot as factory one I took out. Plug number 14 has some heat damage at plug into gem. Light blue wire, wiper park sensor ... is there another module or something between signal switch control, relay, gem, wiper motor? I’ve checked ground at wiper motor, it’s good.
Dale Massey
Aftermarket Products
01-31-2019 10:14 PM
txazguy
6.7L Power Stroke Diesel
03-24-2017 04:47 AM
04F-250mark
03-07-2012 11:32 AM
homedepothauler
11-12-2002 09:21 AM
Quick Reply: Gem module
