electric fuel pump conversion
how do all, I was wondering if it is possible, due to budget, to perform the electric fuel pump conversion in steps. by that I mean could I remove the mechanical pump and install the electric pump on the frame, but retain the stock filter housing and regulator? I would use high pressure hose and run from the stock pump supply line on top of the engine to the fuel bowl inlet and then use high pressure to run to a three way fitting, and a bit more hose to join the fitting to the stock lines running to the head. later as budget allow I will replace the filter assembly and regulator and then the lines to the heads.
thanks guys
thanks guys
You can't really do that because the stock pump is a two-stage pump. The first stage pumps the fuel into the fuel bowl at 6-7 psi. The fuel then returns to the pump to be pumped to 70 psi or so before it goes through the heads and to the FPR and back to the tank.
If you tried to pump fuel into the fuel bowl at 70 psi, I'm certain it would fail in short order.
thanks for the quick answers....
so let me ask this a different way then. my current problem is I have a California truck with the diaphragm on top of the banjo fitting. the dang diaphragm has developed a hole and is leaking quite badly. is it possible to cut the diaphragm from the top of the lines and seal the hole either by welding or maybe tap it for threads and us a brass plug. I would just replace the lines but they are running about 120 bucks plus a new shorter banjo bolt.
I believe it. I'm compiling parts now and am still under $400; just need a couple fittings and some wiring pieces from the junk yard. If I was doing the tight wad mod, I'd be just over $200.
lunkerbuster
04-26-2010 12:12 PM
1966Tbird
09-15-2009 05:05 PM
