'93 E150 coolant leaking from trans cooler radiator fitting
I decided to install a trans cooler since I was servicing the trans and got the pan dropped anyway. But when I cracked open the trans cooler connector(which is totally unnecessary and should be avoided completed), I noticed that I broke the trans cooler connector fitting to the radiator and now the coolant leaks badly from aroud the fitting.
What are my options other than replacing the radiator? Would some liquid metal treatment do the magic? Or is there a way to remove and replace the fitting(I am not sure this would be possible since it looked like the fitting was welded to the radiator)?
cohomology
06-25-2016 05:17 PM
finitetime
12-05-2011 07:14 PM
jackstraw
12-15-2009 07:46 PM
