'73-'83 engine swap?
Old 06-23-2016, 07:34 PM
xphr8r's Avatar
xphr8r
xphr8r is offline
Hi, I need to know if a '73 300 (4.9L) 6cyl will fit an '83. They are both f-250. Thanks...
Old 06-23-2016, 10:20 PM
82F100SWB's Avatar
82F100SWB
82F100SWB is offline
Pretty much bolt it in.
Old 06-23-2016, 10:28 PM
xphr8r's Avatar
xphr8r
xphr8r is offline
Thanks, the mounts, and the bolt locations are throwing me off. I wanted to use the duraspark dist, I'm pretty sure it'll fit, but still kinda unsure...
Old 06-23-2016, 11:29 PM
82F100SWB's Avatar
82F100SWB
You will need to use the 83 mounts, oil pan and pickup. The Duraspark dizzy will drop in.
Old 06-23-2016, 11:32 PM
xphr8r's Avatar
xphr8r
xphr8r is offline
That's what's puzzling me, the bottom 2 bolt spread is different. The '73 is closer together...
Old 06-24-2016, 06:25 AM
Franklin2's Avatar
Franklin2
Franklin2 is online now
Received 1,654 Likes on 1,337 Posts
Bolt spread on the engine mount? You are going to use 83 mounts correct?
Old 06-24-2016, 04:12 PM
xphr8r's Avatar
xphr8r
xphr8r is offline
The '83s don't seem to fit. I'm going to remeasure again tday. Check with you later...
Old 06-25-2016, 08:27 AM
Franklin2's Avatar
Franklin2
The 300 block should be the same, so work from there using 83 parts down to the 83 frame.
Old 06-25-2016, 03:32 PM
xphr8r's Avatar
xphr8r
xphr8r is offline
Thanks...wow, how did you get the animated blower avatar? New to! Have you seen fury road?
Old 06-28-2016, 11:53 PM
xphr8r's Avatar
xphr8r
xphr8r is offline
Hi, I thought every thing was all lined up, then I noticed the dip stick. The '73 is in front of the dist, the '83 is behind the oil filter. Jeez, now what?
Old 06-29-2016, 05:51 AM
FuzzFace2's Avatar
FuzzFace2
FuzzFace2 is online now
Received 2,085 Likes on 1,778 Posts
Don't use the timing cover stick and plug the hole.
Dave ----
Old 06-29-2016, 11:39 AM
82F100SWB's Avatar
82F100SWB
Not sure if the 83 will still be stick in pan. You may need an 82 back rear sump pan.
Old 06-29-2016, 06:48 PM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
No 1973 anything came with DuraSpark electronic ignition.
DuraSpark introduced in 1974, but not all vehicles came with it until 1976.
The module used in 1974...is 1974 only / The module used in 1975...is 1975 only.
DuraSpark ignition modules are identified by a colored plastic square located above where the wires feed out.
CalebJns
27
03-30-2010 03:03 PM
jspalmeter
Engine Swaps
03-21-2007 07:45 PM
badriderz
Engine Swaps
04-28-2004 09:22 AM
fordisaac
20
08-04-2003 09:27 PM
Quick Reply: '73-'83 engine swap?
