Sand/media Blasting How much????
And a two stage compressor, (like yours) is the best way to go! Most "oil-less " units only last about 1000 hours.And no they can't be rebuilt (unless you have a machine shop). I can't count how many people brought those cheaper, oil-less compressors into the Sears repair shop in Anchorage. "Can you fix this?"-NO- "It's cylinder walls are worn out" Then most customers threw them into the dumpster on their way out.
From a dead empty (80 gallon) tank to full pressure (175 psi) only takes about 4 minutes for my compressor to get there. An oil-less compressor takes forever to pump up and they seem to run continuously when you are using them. I never have to stop and let the compressor catch up when I'm bead blasting. The compressor cycles on and off and I never have a drop in output pressure between cycles.
Redtail_PDX
06-04-2010 08:54 PM
idealtrucks
03-12-2003 06:35 PM
