1948-56 Front disc conversion question?
I have a used front disc conversion that came with a complete front end removed from a 1956 F100.
My plan was to fit the disc conversion to my 1951 F1 but have noticed the difference in length of the spindles so the rotors won't work. I have seen kits listed as fitting both trucks so I am guessing the rotors are the same with a spacer for early longer spindles, is this right?
Thanks hulleywoodworking I'll have a search again but couldn't find anything last time I had a look, just a case of using the right key words.
Anyhow now I know where the spacer goes and that all it does is sit over the outer bearing and bring the castle nut in line with the holes for the split pin I can simply make one myself. Good news!
Found a thread covering the spacer in question in case anyone reading this is in the same boat as me...
https://www.ford-trucks.com/forums/1...-disc-kit.html
ltdrifter
10-25-2009 03:38 PM
