97 PS. Alternator not turning on..
After getting frank-n-truck assembled, fired right up. Problem being that the alternator won't turn on unless I run a jumper wire from the battery to the alternator harness on one of the pins (can't remember which wire but it was the right one. Ignitor wire?). Problem is that I have to leave it jumped when running and unplug it when I shut it off to prevent burning up the alternator regulator. Now I went through all the oem harness when I did the install and it's in good shape. So what other areas do I need to look at that could be commonly problematic?
joshofalltrades
Electrical Systems/Wiring
11-30-2012 02:58 PM
natewoz
02-09-2007 06:54 PM
highgearonly
01-30-2006 07:58 AM
