03 Ex - drifts left and right while driving - Help
While driving my excursion will drift/pull left then right. Got the truck to pull my camper and feel unsafe. All the research I've done so far suggests the springs need to be replaced for a better ride. However, when I checked my truck this is what I found. Pics attached.
Front
Back
Front
Back
Everything I've seen so far suggests I should have 2 springs all around.. however, I have more in the rear.
Can anyone point me in a direction to start to fix/troubleshoot my steering problem?
Thanks,
Mike
Front
Back
Front
Back
Thanks,
Mike
upon edit from your last post drifting all the time, you have something worn or out of align in the front end. I'd take it to a front end alignment shop. You are missing a rubber over travel bumper in the front, but that is not your wandering problem. Hopefully you will never need the over travel bumper. Those shocks look original too. I am on my third set of shocks, but I have 190000 on mine.
on
You have D code springs in the front and G code in the back. Before you change springs I would have your mechanic look over the front end and check the hubs, tie rods, drag link, steering gearbox, sway bar bushings, trac bar bushings etc. Have you checked to see if the hubs are locked into 4 wheel drive. If possible get under the truck with the truck in park and the brake on and spin the front driveline if it doesn't turn freely you have a locked hub.
When you get to the spring part of the job search or ask about it in the Excursion forum they can tell you what you need.
