Thread sizes, oil pressure & water temp
Chevy_Eater
Where is this? is the the back center of the engine?
https://www.ford-trucks.com/forums/1...l#post13283130
Devin
Devin
It's not seen in the ATS shot, but it's still in the factory location IIRC. And I do think I'm recalling correctly since I had to replace the thing right after installing the engine. Not fun.
Factory ATS draws oil from the same location at the back of the engine. The pressure sender is relocated to the top of the turbo where it tees off some fancy fitting Ford made.
Aftermarket ATS draws oil from the right most port (back of the engine) in the picture that dtgl90vt posted (it is at the right edge of the picture). The oil runs up a tube to a 90 elbow at the top of the turbo. The stock pressure sender is still used.
Another pic/thread for reference. This stupid 1/8" pipe plug is a pain in the ***. 1/4 square plug.
Devin
https://www.ford-trucks.com/forums/1...l#post12113794
Devin
Just for a heads up to those reading this thread, save your self some time and order this set.
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
I haven't got it yet so I can't speak to the usefulness of it, but I would estimate the 1/8" pipe plugs really have a 9/32 head, a 1/4 doesn't fit, and a 5/16 slips.
We tried making a tool to remove the 9/16 coolant plug, took a old 3/8 drive socket, cut the head off a 9/16 wrench and welded it to the socket, even added a 4th side to the wrench to reinforce it. Alas, it ripped apart under the torque.
Anyway, i'll check in after I try the new sockets.
Cheers,
Devin
decapitated 9/16 wrench head welded to 1/2 drive socket
Cheers,
Devin
That looks like a handy set; only I'm not seeing a 9/16
8 point sockets can usually be found on ebay:
Apex 5818 D 1 2" Drive 8 Point 9 16" Square Opening 3 1 2" Deep Impact Socket | eBay
Craftsman Vintage 1 2"Drive 8 Point SAE 9 16" Socket Be Antique U s A Made | eBay
Grey Pneumatic 2518s 1 2" Drive x 9 16" Standard 8 Point Socket | eBay
Is this a port? Coolant or oil? I tried the port to the left, right on the other side of the oil cooler, but the sender kept hitting and I couldn't thread it in. I was able to place one sensor on the port further back. If I have to, my plan is to remove the former, and add a pipe nipple to clear the obstacle. If this plug though in the picture is a candidate I'll take it.
Devin
Devin
#28
Adding for reference.
Found on the IDI Oil Cooler Thread
https://www.ford-trucks.com/forums/1...er-thread.html
Devin
Devin
#30
I know my earlier post may have not made much sense so I decided to add another picture. Still haven't figured out what that other port is though, I'm at work now so if I don't figure it out before I go home, I guess I'm just gonna let her loose and find out.
Thanks Again,
Devin
This is the plug I could not thread the sensor in because its housing was rubbing on the filter header.
And the port next to the Y-pipe.
Thanks Again,
Devin
