Help
Help
Ok so I have an 88 f250 with the 460 and the 5 speed and an 84 f250 6.9 idi with the c6 3 speed. I want to do a swap and put the 6.9 into the 88 and just the motor nothing else, what is all involved and what do I have to move from the 86 full doner truck to the 88? I know that I must swap all fuel lines and such. But what about the 5 speed bolting up, can I just eliminate the torque converter since the 5 speed is standard, and what about the gauge clusters, how do I install a tranny temp gauge, I have aftermarket one. And anything else I'm forgetting. I've never swapped b4 but I have a lot of help just wanna know everything that it entails b4 I begin. Thanks so much!!!!
on
You can't, You need a Diesel ZF5.
No
Yes
It all depends on how much hacking you want to do, the core supports are different, the pedal assemblies are different, radiators are different just to name a few.
Pretty much anything is doable if you want to do it bad enough!
-Enjoy
fh : )_~
Yes
-Enjoy
fh : )_~
Here is one without any rust from the desert, and you even have the spare engine to put in it while you diagnose what is wrong with that bad cylinder. he'll even throw in a turbo kit. And it has 4wd. https://bakersfield.craigslist.org/cto/5622250747.html
on
Though that ATS sure spices up the deal!
-Enjoy
fh : )_~
true. The 4x and the turbo does spice it up, but I'd probably only spend $2k for that truck. maybe the guy would be able to negotiate a little more than the CL post leads on. The only thing going for it is the clean desert body. You can find some pretty pristine 80's parts out here in California and Arizona. My van is from here, and my friend from Wisconsin was admiring my clean frame and body panels and said my van "should be in a museum."
on
There is also the fact that it will not seal leaving a gap at the top.
Yes, it's been done, it's a hack at best!
EDIT:
It appears I may be wrong about the casting and that it will not leave a gap at the top! Type4 has done it, I can't imagine him doing such a hack if the top was left open!
If it's a just a matter of elongating the two top holes ... Then I guess it is not such a bad hack, one I'd do in a pinch ...
Sorry Bashby!
-Enjoy
fh : )_~
