79 f150 2wd 400 to 460 swap
Hello all the 400 in my 79 f150 2wd is shot I got a low mile 460 with c6 for a good price my question is what will I need to do this swap. I have looked around online but all in keep finding is same swap but in a 4wd. Thanks in advance for any info I'm hoping to do this in very near future so 8f I need to order parts I need to do it asap.
(460 is going in to red a black f150)
Swap is pretty straight forward with the c6, you would just have to know what torque converter and flexplate you need because in 1979 1/2 the 460's went to externally balanced, so depending what year engine you have. there are 3 or 4 different size TC they used, you can look that up, as for the oil pan you don't have to swap it if you doing the swap in a 2wd as you said, but a 4wd you have to find a rear sump truck pan, so you should be good there, you need truck/van manifolds also, car will not fit without notching frame( i have 1985 460 truck manifolds for sale if you need them). and engine mounts, i know im missing a little bit of stuff but this should give you a good outlook on the swap, have fun! you would also have to maybe get a bigger radiator, some 351m/400 came with the big core some didn't.
robert.royal
16
10-16-2012 08:25 PM
