Fan removal?
Here's what the catalog shows. The only one that fits a truck with a 351 and A/C is D7TZ 8146-A. And note that under description it shows D7TA-AA. That's usually what the part has stamped or printed on it. Futher up in the catalog for a 302 there's a D8TZ 8146-B and it is marked D8TA-BA. So, I believe JBG is wrong. The part they have should not be a D8TZ 8146-B and be marked D7TA-AA. Those are two different parts.
Here's the info, but I've only included the first usage of C8TZ-8600-B, the 18 1/2" fan, to the bottom so you can see what other applications used that fan. I'm betting you have the 19 1/2" fan.
However, note the center hole differences. Perhaps that's due to the clutch? Here's the info on the clutches.
#29
#30
For the 1980 - 89 trucks there are two vendors for the catalog: HIPO Parts, and David Forell. The HIPO version is 5000+ pages of jpg pictures, which cannot be searched. However, with a bit of work and the right software you can run an optical character recognition (OCR) program on it and make it a searchable PDF. That has huge benefits, and is what I've done to my HIPO copy.
David's 1980 - 89 version has already been OCR'd. However, it wasn't done very thoroughly and there are many misses such that when searching for things it may well not find them. I've had many discussions with David and explained the problem and suggested a solution, but he wasn't interested.
