"Improved" diesel fuel economy and regeneration process?
I harken back to the '90's when I purchased a Ranger to supplement my aging F350 flatbed with a 400. Mileage in the 350 was 10-12 loaded or empty. Ranger was over 20. Made the payments with the gas savings and had more to support our Daughter at Syracuse U. Investment in her was best. On the correct trailer the Ranger could pull safely a 3000 lb boat and trailer. Another boat only weighing 1200 lbs on a narrow/high trailer dragged the Ranger all over the road. Same can be said for even twin screw tractor trailers. Cheap suspensions and light frames are a real challenge to drive at highway speeds. Good suspensions and strongly built trucks are safe at highway speeds and above. 80 mph and 80K gross no problem in the right truck. As you said The State is attempting to mandate every aspect of transportation and we as consumers will bear the lack of freedom to pursue our pleasures, or occupations without dear cost to safety and pocketbook.
And, if you look in the towing specs for Ford, that's likely out of the specs for the F150. You need to reduce your towing weights as the front surface area of the trailer increases.
http://www.ford.com/resources/ford/g...0_r1_Jan12.pdf
Frontal Area is the total area in square feet that a moving vehicle and trailer exposes to air resistance. The chart shows the
limitations that must be considered in selecting a vehicle/trailer combination. Exceeding these limitations may significantly reduce the
performance of your towing vehicle. Selecting a trailer with a low-drag, rounded front design can help optimize performance efficiency.
And then the weight police shows up.
I have been towing for 38 years and more than likely have more towing experience than you and most of the rest here. Everything from cattle to hay to farm equipment to RV's. . Also have had 3 Super Duties and 6 or more half tons.
The 92 F150 with a 351 V8 struggled with a 10k load- stability wasn't a problem but power was. The 05 SD handled it easily as did the '11 and '13 ecoboosts. It wasn't until Ford lightened them up that issues arise. You might not think so but that 700 lbs that is missing makes a big difference.
If you have been following me around here for years then you should have know that I had a '15 Super Duty before this truck....
QUOTE=fordmantpw;16377545]Why would you want to do that? That just wouldn't be the smart thing to do.
See, Ford touts the max tow rating, but it's up to the customer to use a little common sense and do the proper research to make sure you meet all the specs and not just one. I've seen several of your posts on several forums over the years. Accept the fact you need a Super Duty and buy one.[/QUOTE]
It has nothing to do with being the weight police, but it has to do with explaining how what you are complaining about is ridiculous since it is outside the capabilities of the truck.
Oh, and I haven't 'followed you', I just remember the screen name (I have a JD myself) and the threads about how you wanted an F150 but needed a Super Duty and how you've not been happy with the towing of the F150 though it is definitely outside the realm of what the F150 is intended for.
Oh well, I'm not going to argue about it. Good day!
