can movies on a phone be watched via dvd auxiliary jacks?
Yea I bought an old iphone4s 64gb just so I could watch movies, netflix, amazon etc on the factory dvd system. Apple makes a cord with the 30pin connector and rca's. But It wont work with the newer lightning plug, it is audio only.
Also if you are planning on buying this adapter, just buy the apple one, a lot of the aftermarket plugs are'nt true 30pin plugs and you'll only get audio on the 30pin apple plug.
How about just using Bluetooth or even a cable from my Android to the auxiliary jacks? Would you please put links to what I would need to get an Amazon to run a cable from my phone to the DVD Jacks and watch a movie that way? I am really illiterate when it comes to this stuff
http://https://www.amazon.com/Microsoft-Wireless-Display-Adapter-v2/dp/B01AZC3J3M/ref=sr_1_1?ie=UTF8&qid=1466862310&sr=8-1&keywords=microsoft+wireless+adapter
https://www.amazon.com/COWEEN-Adapter-Converter-Suppport-Connector/dp/B01RMKRW/ref=sr_1_4?ie=UTF8&qid=1466862348&sr=8-4&keywords=hdmi+to+rca
https://www.amazon.com/Kimdrox-Adapt...12+volt+to+usb
Each other these require USB power, I hard wired a few 12 volt to USB cables for them. The wireless adapter plugs into the HDMI to RCA converter, which plugs into you RCA jacks. You mirror your phone to the wireless adapter (screen cast) and what's on your phone will be on the screen. You use it going down the road, the WIFI part is just to connect your phone to the wireless adapter. Hulu, youtube, Amazon prime all work. Netflix is glitchy, but other adapters like the chore cast or the fire adapter may work better.
