Compass & Temp Modual, its two lights, & courtesy lights OUT
Hi there - My compass and temp display, its two lights, and all courtesy lights are out. Does anyone know of a fuse that can cause this? I checked the fuses on the left side of the stearing wheel, could not find one that was bad. Not sure where else to look. Because of all the other lights being out, I think it is a fuse or wire. Help... having trouble finding exactly what all the fuses go to.
Thanks in advance.
2003 Ford Explorer Sport Trac
6 cyl, 2 whl dr,
Thanks in advance.
6 cyl, 2 whl dr,
Thank you for the Fuse #. Is that in the fuse panel on the left of the wheel inside the vehicle? However since the turn signals work, that probably is not the problem.
What about all the courtesy lights, the ones that are supposed to come on when you open the door or turn the dial for brightness on the dashboard lights?
Thanks in advance for your help!
here is the operators manual... look toward the back like page 135- 140 for fuses.. You may have a second problem with the other lights. ........ I would look at the power to the console first and see what you find out.
Owner Manuals | fleet.ford.com
lebanontn
05-14-2011 08:40 AM
Glockem45
1999 to 2016 Super Duty
01-12-2006 04:18 AM
