I bought an Early 99
Moral of the story don't give up on her yet. Make sure drivetrain in good and fresh fluids everywhere before getting frustrated. I know that easier said then done. These are great trucks. They just need a little TLC before you see the good side, especially if the previous owner wasn't a regular maintenance person.
I love my early 99. Besides the cost of injectors
I hope your right, truck ran awful this morning. New problem. It acted like it was running out of fuel for a while then it just seemed low on power. I'm at about 1/4 tank, I'm gonna fill it up and see if that problem goes away. Might just be something wrong with the pick up.
I was really hoping to just drive this truck and not have a bunch of repairs to do. Truck has 175,000 miles. My 97 is 10x the truck that this one is so far.
The running rough from time to time could be the need for a fresh oil change. I know my truck runs rough when it time to change the oil. My truck does the blue smoke as well, but I know that I need injectors. Just don't have the money right now. My truck kinda does the tranny things too. I really think you are describing normal characteristics of the 7.3 superdutys. In my opinion that is.
Cowmilker,
My truck is also the same color and has the typical early 99 bad paint... I notice your clear coat looked faded but mine chips off. Quick tip is to buy tough up paint from ford and chip the clear coat away then touch up paint it and clear coat it with the clear coat that comes with the tough up marker along the edge. It has stopped mine from continuing to peel for almost a year! Good luck with your truck!
Is that something that needs addressed soon? Or if the turbo shaft play is good, then don't worry about it?
I suppose it could be, but my OBS powerstrokes don't make this particular noise.
So its normal for it to be jerky at like 35 mph? I do need to change the oil and fuel filters. Hopefully the fuel filter isn't black, but I bet it probably is. With 175,000 miles, its probably about due for some fresh injectors.
Welcome to the early 99 club! haha I love mine except for the smoke... Firefighter, you said you need injectors cause it is blue smoking... I am wondering if mine is smoking because of the injectors... Can the injectors make it smoke other than the external o rings?
The 1/4 tank running rough is probably the pick up foot fell off in the take. I actually am going through the same thing with my truck right now. I would start filling up before that until for get it fixed. Don't push it too much or your gonna burn up your fuel pump. Have you done fresh fluids and filters? Fuel, oil, air?
Filters/oil will come after RRE. Is anyone else here going?
I think the picture is deceiving on the clear coat. It actually just has 2 small spots where the clear coat is peeling. I'll give the touch up kit a try. What's the best way to chip around the area to be touched-up?
#28
I haven't worked on it yet at all. I've only driven it about 250 miles since I bought it. I just got home from RRE last night to find a puddle of ATF under the truck. I'm gonna look at it real hard to make sure where the leak is because the puddle was about a foot behind the inspection cover.
I have Torque Pro to read codes, just haven't done it yet.
No CEL yet.
No CEL yet.
#29
#30
I'm sure they could have but I drove my 97, and plus I was on vacation. The last thing I wanted to do was think about problems. RRE was a blast again this year! I met up with some guys I met last year and met plenty of new people too.
I think my ATF leak was coming from the dipstick tube where it goes into the trans. I've got pics and a video to upload later today.
