1978 - 1996 Big Bronco
Bronco 2.0
Old 06-19-2016, 11:44 PM
Raleigh1's Avatar
Raleigh1
Raleigh1 is offline
Bronco 2.0
Well unfortunately it is time for a new build thread
I have been making changes to the Bronco over the past few months which include bumpers, sliders, quarter protection, twin stick and had plans for a full cage in a couple weeks.
So obviously the direction of the Bronco has been evolving and I have been enjoying wheeling it pretty hard.
Well this weekend in Moab the unthinkable happened
Poor thing looks like it had a stroke...
I was able to drive it home from Moab to Vegas with no major issues.
The major issue currently is that the firewall buckled and separated from the floor pan. It looks as though it will pull straight fairly easily but I need to pull the engine to massage the buckle.
The other issue is that the A pillar may be bent slightly, although the glass did not break so if it is bent it is very slight. I will have to investigate that later this week.
The core support and driver fender is trash.
So the plan is to repair the firewall first, check out the A pillar and then start repairing sheet metal.
I love the white pearl however it is impossible to touch up scratches or paint any portion of the truck so a color change is also in the works.
Color is a bit up in the air but I am thinking a matte silver would be nice.
Well, there it is, I'll be working on it this summer, hope to have it back on the road mid to late August.
Old 06-20-2016, 08:14 AM
masseysbronco's Avatar
masseysbronco
masseysbronco is offline
Ouch, at least you have the skills to repair it yourself though.
Old 06-21-2016, 12:15 AM
Encho's Avatar
Encho
Encho is offline
The Southernmost Mod
That sucks, but I'm confident on your skills, it will be looking dandy once again soon enough.
Old 06-22-2016, 07:37 PM
bigzirb's Avatar
bigzirb
bigzirb is offline
I'm glad you got out of it ok! I'm guessing the cage has moved up on the list as soon as you get the sheet metal fixed? Other than a color change are there any big things that you were unhappy with before that you are planning to change on it this time around? We have all seen that you have the mad fab skills to rebuild it, just curious if things are going to change a lot or not.
Old 06-23-2016, 02:44 AM
Bubba Jones's Avatar
Bubba Jones
Bubba Jones is offline
This makes me sad, but I know you'll be able to fix it up again! It makes me even more nervous to wheel mine... I almost rolled once. I've never gone back to that hill and don't plan on doing that either.
Hopefully it isn't too much work to try and get it back to the condition it was. I've done a lot of modding and painting, but I can't say I'm good with body work at all. Body work/welding seems like it would be a lot of work..
Old 06-27-2016, 04:52 AM
78_f800crewcab4x4's Avatar
78_f800crewcab4x4
78_f800crewcab4x4 is online now
I have a lot of the cab sheet metal you will need here in Vegas. Including the metal roof and core support.
Old 06-29-2016, 10:56 AM
Toyman's Avatar
Toyman
Toyman is online now
Dang that suck Raleigh. Glad you are ok, the bronco can get put back together!
Old 07-01-2016, 07:52 PM
rollerstud98's Avatar
rollerstud98
rollerstud98 is offline
Old 07-24-2016, 08:37 PM
Raleigh1's Avatar
Raleigh1
Raleigh1 is offline
Got some work done on Bronco 2.0 this weekend. Mocked up the body and moved the axle to its new location. Also removed a couple of leafs from the spring packs, hoping it will come down 3-4" when all said and done.
Ended up at 98", pushed the rear hangers as far back as possible, took out 2 leafs from each pack and flipped them around backwards. Will need to shim the axle a slight bit for pinion angle.
Old 07-25-2016, 10:14 AM
bigzirb's Avatar
bigzirb
bigzirb is offline
I was confused so I had to check on the build thread on FSB to find out your tub was twisted and you are putting an Early Bronco body on the 78-79 chassis. I look forward to watching you work out the details of the swap. It's a crossover Bronco that fits in Early Bronco or Full Size Bronco categories. Keep up the great work.
Old 07-25-2016, 03:31 PM
ManfredVonRichtofen's Avatar
ManfredVonRichtofen
ManfredVonRichtofen is offline
I would create lots of support for the firewall and front end.
hell..build a whole cage around the whole body.
Old 07-25-2016, 07:32 PM
Raleigh1's Avatar
Raleigh1
Raleigh1 is offline
I am planning to build an internal cage and some tube fender flares that tie into the cage.
Old 07-25-2016, 07:54 PM
ManfredVonRichtofen
oh. i just thought an external cage will be good for a roll over. already hard to find a good 78-79 bronco
Old 07-25-2016, 08:39 PM
Raleigh1's Avatar
Raleigh1
Raleigh1 is offline
True, that's why this is an early Bronco body goin on! haha
Old 07-25-2016, 08:55 PM
ManfredVonRichtofen
O I see now. Didn't see that...and even then those earlier Broncos are $$$$ too.
Quick Reply: Bronco 2.0
