360/390 Power steering mounting bracket
My 1973 360 came without a power steering pump attached (it sits in my garage), my question is: what mounting bracket could I use to attach a power steering pump to my 360?
I have read that the bracket from a 352 engine would do fine.
Any input is appreciated.
Nick
Nick
It might help to see a picture of your power steering pump. Most PS pumps have a small bracket that attaches to a larger bracket that attaches to the driver side cylinder head and water pump. Also, you'll need to confirm that you have the appropriate pulley on the crankshaft balancer. You'll need to have at least two V grooves. The first is for the alternator and water pump. The second is for the power steering pump. A third V would be for an A/C compressor.
To the OP, you say you already have the pump. Just be sure it's the correct pump. Ford used the Thompson/Ford pump for years and years. It's ID'd by the all metal housing and often called the "pencil neck" pump because of the small filler neck. In '78 Ford changed the pump to one that has a large plastic housing. The pumps don't interchange and there aren't any brackets that will bolt the plastic pump to a 360.
Here's what the setup looks like. This engine has A/C but that doesn't make any difference. The power steering brackets are the same. The only difference is, without A/C, you need to put a spacer between the bracket and cylinder head. On A/C cars, the compressor bracket acts as a spacer. The bracket that bolts to the pump has three studs that stick through slotted holes in the bracket that bolts to the engine. This allows for belt adjustment.
The following users liked this post:
D3TZ-3C511-A .. P/S Pump Support Bracket-Use with Ford/Thompson P/S pump / Obsolete
1973/76 F100/250 2WD & F350 360/390 / 1973/76 F100/250 4WD 360.
GREEN SALES CO. in Cincinnati OH has 3 = 800-543-4959.
HIGH BUCK! BOB ALLEN FORD in Overland Park KS has 3 = 913-381-3000.
D1AZ-3A732-A .. P/S Pump Adjusting Bracket-Use with Ford/Thompson P/S pump / Obsolete
1971/76 F100/350 360/390 / 1973/77 F100/350 460 / 1977 F100/350 351M/400.
1971/72 Thunderbird 429/460 (460-1972 only) / 1971/73 Galaxie/LTD/Torino & Mercury Marquis 351C/351W/400/429.
1974/76 Torino 302/351W/460 / 1974/76 LTD/Marquis 351W / 1975/77 LTD/Marquis 351M/400.
1977 Cougar/Thunderbird/LTD II (not an LTD!)/Ranchero 302/351M/351W/400.
NOS PARTS LTD in Waxahachie TX has 1 = 972-937-2201.
Amazingly, no FoMoCo dealer, no other obsolete parts vendor has any.
crazy96863
01-09-2017 08:14 AM
73Custom
03-13-2016 11:07 PM
e6ug
06-03-2013 04:22 AM
workingdog
15
11-22-2005 03:06 PM
