Back glass interchange years?
06-19-2016, 04:19 PM
Wann swap the broken rear slider in the 73' for a solid rear glass. What years rear windshields will fit the dent side cabs?
06-19-2016, 04:31 PM
Quote:
Originally Posted by
GM4WALLS
' 73 for a solid rear glass.
(back window or back glass) will fit the dentside cabs?
ALL 1973/79 F100/880's use the same clear or tinted back window glass.
06-19-2016, 04:35 PM
NumberDummy
Thank you sir, you're a gentleman and a scholar!
I thought I read somewhere that 80'- early 90's will fit as well, any truth to that?
06-19-2016, 04:43 PM
GM4WALLS
Well, consider that...
Sliding rear window interchanges: 1973/96 F100/350 & 1997 F250 H/D & F350.
The 1980 and later glass is a bit thinner than 1973/79.
06-19-2016, 04:47 PM
NumberDummy
I found a solid glass in a 76' today, will head back and grab it. Thanks for the info.
06-24-2016, 08:37 AM
on
NumberDummy
I love this site. Many thanks to you, NumberDummy. I don't know you but you've answered at least a dozen questions for me over the last year.
03-10-2022, 11:55 PM
on
Thinner glass
NumberDummy
Does the thinner glass present a problem? Too loose to use? My 79 needs a new back glass and I haven’t found many donors to plunder.
03-11-2022, 12:46 AM
Old thread.... My understanding is the thinner glass needs the matching seal for thinner glass. Use the one from the donor if possible. If not new replacement seal for the year of the vehicle taking the glass from.
Ps. Do a search do not quote me on that I have not done it before/yet. 99% sure
I know I read it on FTE
The following users liked this post:
03-11-2022, 07:16 AM
Interchange years are 1973-1996. 1997-1998 if you count heavy duty trucks.
Just buy a matching seal to the year of the glass and problem solved.
This 95 fit perfectly in mine.
The following 3 users liked this post by jackietreehorn:
crazy96863
07-07-2020 08:45 PM
dantennant_22
Washington Chapter
04-11-2007 08:16 PM
dantennant_22
01-08-2007 04:36 PM
bigdog50
10-08-2005 12:30 AM
crack
05-05-2005 10:11 AM
