53 F100 radiator support mounting
Does anyone have pics of the radiator core support mounting to the frame on a 53 F100? My diagram shows two rubber bushings that go between the frame and support but there are no existing mounting holes. I didn't want to add these if they were not there originally and risk throwing off the front sheet metal alignment. I don't remember seeing them when I tore it down years ago
Any suggestions?
Any suggestions?
Two bolts attach the U-shaped radiator support to the frame. With the rubber spacers installed, the support can rock side to side. Rubber bumpers are also part of a correct installation. These bumpers limit this side to side rocking, and absorb some of the twisting forces that result from moving across uneven terrain. The best graphic I know of to illustrate the support set-up comes with the instructions for parts from Mid Fifty.
Instructions - Mid Fifty F-100 Parts
bluestang65
20
06-25-2014 10:43 AM
Flybear2000
23
04-03-2012 09:40 AM
