Less boost after SPX Turbo Wheel
So I have been having all types of problems with my truck but it's finally running again. I replaced the manifolds and EBP sensor, which created proper amount of boost and blew a seal in my turbo causing me to lose about 3 quarts of oil in 15 minutes. I rebuild the turbo and put an SPX wheel in it as that's what you guys recommended from SPturboost.com. Before I could get about 15 psi without much problem, just stick my foot in it. Now I have to stick my foot in and leave it there for a bit longer before it builds up to 10, it seems like it's happier at around 10-12 psi. It is the 5+5 blade design, like the OEM wheel. The original wheel looked like the blades have been worn down and out of square from the last. 248K that it has been through. Does this make any sense to you guys? On the website they claim this wheel gives an extra 4-7 psi.
