1999 7.3l EGT probe
06-16-2016, 09:25 AM
on
1999 7.3l EGT probe
What is the best location to mount the EGT probe in the exhaust manfold and what side of the engine to use.
Thanks
Charlie
06-16-2016, 10:00 AM
I mounted mine at the bottom rear part of the drivers manifold. You've got a straight shot at it so you cand drill and tap, lying on your back.
pyro location psd
06-16-2016, 10:07 AM
on
Quote:
Originally Posted by
binuya
pyro location psd
This is where most mount it. It is the easiest location to access, and it gives very accurate readings since it is close to the cylinders.
06-16-2016, 10:19 AM
You can also have two pyros if desired, to see if both banks are consistent.
06-16-2016, 09:11 PM
Just remember to wear some safety glasses or goggles. Piece of metal in the eye is no joke.
06-16-2016, 10:01 PM
And when running the tap do not run the tap all the way in or the hole will end up too big, that's a tapered tap/hole. I'd say try 1/2 way first and see how it works, if you need more add a turn or two.
Hit Man X
15
07-09-2018 07:07 AM
mikec91
04-14-2012 05:36 PM
jayhawk714
07-29-2011 07:50 PM
menmy02x
07-09-2010 11:34 PM
jeffreystar
03-15-2006 10:05 AM
