black smoke?
Old 06-15-2016, 10:15 PM
clean '97's Avatar
clean '97
clean '97 is offline
black smoke?
not changing my oil in over 10,000 miles.
will that have an effect on the black smoke coming out my tailpipe under load?
i have 215,000 miles on it and the injectors still seem fine. i just barely passed
emissions out here in colorado. where should direct my attention?
Old 06-15-2016, 10:17 PM
fordpride's Avatar
fordpride
fordpride is offline
It could cause the injector not to fire efficient also that 10k mod isn't helping you either
Old 06-16-2016, 01:15 AM
97-psd's Avatar
97-psd
97-psd is offline
why have you gone so long between oil changes? If you are running normal dino oil then I would change it. Do you do oil sample testing?
Old 06-16-2016, 09:50 AM
oldbird1965's Avatar
oldbird1965
oldbird1965 is offline
'clean 97' doesn't like 'clean' oil, clean motor or a motor that will last! Sorry, I don't mean to criticize but I just went 7K on Schaeffer's oil and felt bad about it. I run a oil by pass also. My oil sample came back good though.
Old 06-17-2016, 07:05 PM
clean '97's Avatar
clean '97
fordpride is online now
__________________
Mike
Click here to join the Louisiana chapter
2014 RAM 3500 cummins
96 F350 CC ZF5 53k with grandpas package
thanks for the info mike, the 10k mod was removed 2years ago when i got the ts 6 position chip, just had not updated my signature yet.
be nice glenn. actually 10,000 miles was the last time i changed the oil personally,but i just ran across a jiffy lube receipt from 2800 miles ago. sometimes its hard to keep track when u only put about 1000 miles a year on the vehicle.i was just hoping for a simple fix.
back to my post,right at the limit for passing emissions. 35% opacity at 40 mph. with the chip removed. engine has good compression. before i dump money on new injectors i was just wondering what else i could check and eliminate from the equation
__________________
Old 06-17-2016, 07:26 PM
oldbird1965
I'm always nice John, LOL. I should explain, 90° of my miles are very hard pulling miles. I'm always working it hard pulling 17K pounds and I don't have a light foot. But traveling across the country sometimes I don't have a place to change the oil. That's why I run what I feel is the best oil, Schaeffer's, because it doesn't get sheared down by the hpop.
Old 06-17-2016, 07:43 PM
fordpride's Avatar
fordpride
Chip actually removed or just in stock position?
Cause most "stock tunes" are a little beefed up.
Old 06-18-2016, 10:13 AM
Bob_T's Avatar
Bob_T
Bob_T is offline
I think black smoke is due to either too much fuel, not enough air or all of the above. How is your turbo boost pressure under load? If your turbo is acting up and not delivering enough air it could cause black smoke under load.
So that you have a better idea of what's going on in your motor, extra gauges such as turbo boost and exhaust gas temp or some sort of scan gauge are just about a requirement on these trucks if you're towing heavy loads.
Gunnerboy
02-03-2016 09:14 PM
Dr. Johnson
32
03-17-2013 11:51 PM
hiredgun18
26
09-24-2010 09:37 AM
no limit
1997 - 2003 F150
03-04-2009 10:53 PM
jjed2007
Oil & Lubrication
15
02-24-2008 11:34 PM
Quick Reply: black smoke?
