Part fell off now my a.c. doesn't work what is this part
If it doesn't engage with the shims then remove the shim.
Looks like the bolt came loose and vibrated out.
It should work again after installing.
Once there is so much wear the clutch magnet can't engage. A common mod is to remove shim witch is a tiny washer inside the hole of first pick.
If you decide to go with a Ford part you will likely need 6S4Z19D786AA, we have it available here: #6S4Z19D786AA: CLUTCH. Clutch & pulley. CLUTCH PLATE & HUB ASSY. COMPRESSOR CLUTCH. ... If you need the nut is is part number W710491S437 (#W710491S437: NUT (Pack of 4))
Got it working for $2.00 thanks to you guys I bet if I took it too a mechanic they would have raped me . Yea I didn't think to check and see if the old washers were In there they were. found out the hard way it only took me like 20 min. ended up using three of the washers thanks again guys for y'alls input
Looks like my part fell of somewhere/somehow too. No idea where it went, AC stopped cooling and when I opened the hood noticed it was gone.
If I just buy the clutch hub assembly More Information for MOTORCRAFT YB3030 and mount it back on and measure the gap, should I be good to go?
