Crew cab rear leaf springs
Hey all. I have a 1975 F250 crew cab, 2wd. I would like to get new rear leaf springs for it as I'm sure they're sagging compared to a new set.
Everywhere I look for new Springs, they are all 3" wide. I've measured and mine seem to be 2.5" at the busing. Can anyone confirm this and perhaps give me a place to get a new set?
Hey all. I have a 1975 F250 Crew Cab 2WD
Everywhere I look for new Springs, they are all 3" wide. I've measured and mine seem to be 2.5" at the bushing.
1973/75 F250 2WD Crew Cab: There are 3 different rear springs due to 3 different load rates.
The spring pack (less auxiliary spring) has 6 leaf springs (C7TZ-5560-F) w/a 1700 lb. load rate, or 6 leaf springs (D3TZ-5560-L) w/a 2225 lb. load rate.
Or 9 leaf springs (C7TZ-5560-G) w/a 2700 lb. load rate. These springs are 26" > > eye bolt < < 26"
1965/66 is different, some 1967's are the same, as are some 1968/72's without Flex-O-Matic rear springs that are: 24" > > eye bolt < < 32"
No Ford dealer or obsolete parts vendor has any others.
mikeo0o0o0 & HIO Silver may know of aftermarket sources.
And guess what I just found.
1967 - 1979 F250 leaf springs - front and rear
Scroll down to "rear leaf springs" and you will find a section for 73-79 f250 2wd crew cabs. Woot woot.
Here's the 2400# rating: http://www.generalspringkc.com/product_p/43-485.htm
And here's the 3200# rating: http://www.generalspringkc.com/product_p/43-485.htm
Doesn't quite match up with your numbers but at least it gives you options.
77fordcrewcab
06-28-2004 07:23 PM
