With the spare out of the way you should be able to pop the key off the winch with a sturdy screwdriver. Chuck the key and the mating part that goes onto the rod into a dark bottomless hole. The hole on the bare rod will fit on the winch and work fine.
Thanks for the reply. There is a plastic funnel attached to the hoist( a guide for the rod and key). Do I just rip this out of the hoist to be able to see, and locate, and pry out the matching key. There is no way to see or get a screwdriver in there without getting rid of the plastic funnel guide.
Just unbolt it, only 2 nuts. Once out you will just pry out the piece that the key fits too. It comes out with little effort. Now the rod will fit the slot you just made.
