DEF Half full, Truck went into 500mi Countdown
I always keep on top of the DEF level on my 2016 F250 and never had this happen before. I was coming home the other day, and a message popped up saying that I was going into a 500mi DEF Countdown. I knew that there must have been at least 2.5 Gallons of DEF on board, since I checked the Level prior to making the 300mi round Trip and got an OK reading. So when I got back Home we dumped in a 2.5gal Jug of DEF, and she overflowed with about a quart of fluid left in the Jug. Has anyone else experienced this, and is it a defect with the DEF system. Hate to fix it if it isn't broke................Lew
Lew, sorry to hear of your troubles,
Yes, this has been discussed to great detail, many times.
You could try doing a search on this forum, using the forum tools tab.
Your trucks computer could be confused or you may actually have a problem.
It has been suggested, that you only fill the DEF tank when the truck tells you to. you will get plenty of advice on the subject shortly. LOL
Good luck !
Good luck !
On 3/4/16 I had the 500 miles to empty message appear. After getting that message I drove another approximately 208 miles that day. That evening after checking the mileage since I had previously filled any DEF (2344 miles driven since 8/26/15 last fill), I added a 2 1/2 gal jug of DEF, it overflowed with a cup or two of DEF in the jug. Since that time have not had any more messages concerning DEF. Next time I get a 500 mile message I am going to wait for about 300 miles before adding DEF. Note - always use the Ford DEF fill spout even when you think its going to take more than one jug to fill the DEF tank.
Last edited by gwg42; 06-15-2016 at 07:39 AM. Reason: typo on mileage driven that day
Same here. 2016 F-350 6.7 Diesel. Three weeks old. DEF 1/2 full message. 1100 miles on the odometer. Did not even take a full 2.5 gallons. Message now counting down from 500 miles and won't go away. Service appointment for next Tuesday. Every time I have this problem that Ford can't seem to straighten out, the dealer will have to fix it on warranty. Yes, it's the EPA, but it seems to me Ford can figure out a better way to monitor the fluid level, because what they have, isn't working.
Wes,
Once I topped off my tank, and drove it 3 or 4 times, the message did clear on its own. I was a little concerned about it, but becoming less so.
When I took delivery of my truck the dealer must have not topped off the tank because I got the 1/2 full warning almost immediately.
Being new to DEF/DPF/SCR/ETC.... (coming from a 2004 6.0L with no emission stuff left) I topped it off instead of waiting til it got low.
After reading of others "confusing" the system by topping off, and most having better luck by running it to the sub 200 mile range.... I decided to go that route from now on.
So far so good.
I have no big trips on the radar for the next 4 weeks, so I am going to wait to fill the DEF until I see the less than 500 miles to go on the DEF tank.
Two times I have seen the countdown on my 2015. First time it cleared right away - as soon as I topped off the tank. The second time, it was several drive cycles to clear, to the point I was about to make a service visit, when it cleared.
I like to wait until I see the less than 1/2 full message and then I top it off, so at least the computer sees an increase in fluid. At times I will top off - especially if I have that cup or two left in a Jug... I don't like to force any in, since it does freeze. I realize that is not an issue for everyone though.
If Ford wanted you to fill it every oil change, they should have given us a bigger DEF tank. Kinda like why do hotdog buns come in packs of 8, but I have to buy hotdogs in packs of 12.
When I filled the fuel today, and I also topped of the DEF. It had lass than 50% full message. I ran the diesel tank message to 30mi to empty and I put in 22 gal. There was still 4 in tank.
In put in 2.07 gal of DEF at the fuel station. The info display immediately said that DEF was full after start.
I will repeat the next time I get the DEF at less them 50% message.
Miles today. 2005.1
Miles today. 2005.1
