smoking truck. suggestions?
06-14-2016, 09:48 PM
on
my 1996 f350 with the 7.3 has been smoking. when i accelerate hard it pours white smoke like crazy. I'm not losing any oil and she runs well. Burning diesel like crazy. it smokes a little in idle too but not bad and once I'm on the interstate it almost stops. i think its an injector just peeing diesel but I'm not sure. i think I'm gonna just check them out just curious what y'all think.
06-15-2016, 04:52 AM
Moved to 1994.5 - 1997 7.3L Power Stroke Diesel forum.
06-15-2016, 06:15 AM
White smoke is cold unburnt fuel or coolant. Does the smoke burn your eyes/throat or does it have a sweet smell to it ?
06-15-2016, 07:54 AM
on
Quote:
Originally Posted by
fordpride
No definitely smells like raw diesel that's why I'm leaning toward injector
06-15-2016, 08:26 AM
Most likely an injector, talk to Jim at Rosewood diesel he can help with your injector problems.
06-15-2016, 08:32 AM
on
z31freakify
aSweet glad u agree I can check them and change them just wanted some feed back fore I tear my truck apart
06-15-2016, 08:46 AM
Just hold that thought, do you have any blow by? low compression can also make a truck smoke white and smell like raw fuel.
06-15-2016, 09:02 AM
on
z31freakify
I pulled the oil cap off while running not really a lot of blow by nothing abnormal for this motor I don't think. And I'm not lacking a substantial amount of power either which happens with low compression right?
06-15-2016, 09:04 AM
rev up to 2000 RPM, does the oil fill cap blow off when put on upside down?
06-15-2016, 09:15 AM
on
knottyrope
I'll do that a little later and let u know. Low compression is caused by bad piston rings right?
06-15-2016, 09:41 AM
Blow by is usually rings with that test or cylinder worn.
Low compression can be above head gasket and valves not seating right.
06-15-2016, 09:54 AM
on
knottyrope
So we're talking breaking down the whole motor or a new one if its not the injector
06-15-2016, 10:16 AM
Drive it till it blows, you will be surprise at how long they will go, trust me Im still trying to blow mine.
Reason: stupid spell check!
06-15-2016, 10:19 AM
don't assume anything yet until you start testing and post results
06-15-2016, 10:33 AM
