Intergrated Brake Controller
Haven't towed with my '16, 6.7, F-350, I have only 500 miles on it. Been reading the book regarding the settings on the brake controller, they suggest starting out at a 6.0 gain setting, but don't say anything about starting with a medium or high setting. I will be towing a 35', 5th wheel weighing 14K. Anyone towing similar weight, what do you have the controller set at?
John
John
I have not used an integrated controller but have used many different types from old school that hooked to brake lines to more modern ones on many different cars & trucks towing many different types of trailers.
IIRC I started off on the high side and worked down till I found what worked for me on each trailer.
I look at it best to start high than too low and not be able to stop.
Dave ----
Dave ----
John
John
But I also always use Tow/Haul and the Engine Brake feature when towing. The truck/engine/trans do most of the work it seems.
I can only feel the trailer brakes when I have to do a hard unexpected slow down and the trans/engine brake don't have time to engage all the way.
And even then it's only brief before the truck start doing it's job.
If it is like mine, it won't have the same feel as any other controller. The truck does most of the work. I have mine set at 10.0. Rarely does it feel like the trailer brakes are doing much stopping. They are working properly and if I do a manual stop with the controller the trailer brakes will stop the whole rig. So it may feel like the brakes aren't working at first. Look in the 6.7L section and there is a thread about how the brakes feel on the newer trucks.
Denny
Denny
Denny
This thread makes me feel much better. I've used both aftermarket and the integral controller that is in my 05 F350 and was wondering if there was something wrong with the integral one because it doesn't feel like it's working. Now I see that it is in the design that it actually works smoother, hence I don't feel it as much. Wheew, what a relief...
