Ford 2004 Ranger: How far back can I slide the bed?
After just three days of ownership, my 2004 Ranger Edge how is reading 0 fuel. Assuming it is the sender inside the tank, if I put the rear end up on jack stands and remove the tires, can I slide the bed back far enough to get to the sender?
Will it slide just on the frame or must it be lifted up?
Thanks!
Thanks!
Many suggest just tilting the bed to one side or the other. Some say just lift the front end of the bed, and support it with a step stool or step ladder, or some 2X4s, cut to a good length. Unless you have help, I'd tilt it instead of trying to slide it. You can use stacks of wood placed under the front of the bed, on the frame rails, to hold the bed and jack it up in steps using a floor jack if nothing else. Just work your way up enough for access, do your sender work, and 'walk' it down, removing from the stack in steps. Take a bit longer, but pretty safe.
tom
tom
if memory serves there are six bolts that hold the bed down and 3 screws under gas door and a clamp on the filler tube and unhook tail light plug or plugs, after doing this for a friend we slid the bed back just far enough to get to the tank ( back of bed was hanging in mid air) careful not to push on hanging bed the tank cap was unscrewed and we replaced the pump and float retightened the tank cap and slide bed back and replaced the bolts and screws,,, not hard to do if you have a couple of friends willing to do a little lifting,,,,tilting to one side might work also,,,others opp to remove the tank ,,,i think that would be the hardest way
Thanks!
Thanks!
tr0y
04-14-2017 05:39 PM
notthemaniusedtobe
31
01-30-2014 04:20 PM
Daves94vert
12-10-2010 04:17 PM
allengoodwine
1983 - 2012 Ranger & B-Series
05-26-2000 12:45 PM
