Good nut to check on brakes.
What a wonderful spring day for a test drive. My new self adjusters on my front brakes work perfectly, stop fast and straight. However while on my cruise I had my transmission linkage come loose which had me under the truck alongside the road making the necessary repair. OK here's the part I want to pass on. This repair exposed a situation that could have been very serious. There is a lock nut that holds the pushrod to the master cylinder, mine was loose and when bumped just fell out causing a "NO BRAKE CONDITION" pedal to the floor. I haven't given this nut any thought since I replaced the old Master Cylinder several years ago, but It is obviously one that should be routinely checked if your using the stock M/C set up. Here is a pic of the nut I'm talking about. I also posted a pic I took today on my cruise, if you look real close you can see a fire watch tower at the very top of the peak in the background, called "Sawmill Peak". The Tiger stripes on my door are a little easer to see. I will eventually reshoot that door, at least that's the plan.
Hi Jeffrey, I wouldn't want to answer that as it would only be a guess from me. So I will leave that answer to one of the more qualified folks to answer.
Very timely under the bridge! This weekend I rebuilt a pedal assembly for a 50 F1. New bushings, new shaft, NOS pedals, everything de rusted, cleaned and painted:
Notice the piece I missed! The check nut....I had left it in the solvent bucket. I don't know if I would have caught that or not on the install so thank you very much. That could have been really bad in a few years.
JB
JB
alvald83
03-04-2012 04:46 PM
FozzyNOKI
09-21-2003 10:26 AM
