Ford Truck Parts for Sale Ford Truck related Parts and Accessories for sale
Parts Search
Keyword:
Category:
Price:
Private or Vendor Listing:
Location (State/Prov):
Item Condition:
Cars Search
Keyword:
Year:
(Range)
Make:
Model:
Price:
Mileage:
Color:
Private or Dealer Listing:
Location (State):
53-56 Ford Body parts ( Prices Reduced )
Old 06-12-2016, 07:51 PM
fordman75's Avatar
fordman75
fordman75 is online now
Category: Exterior - Body Parts
Price: $0
Private or Vendor Listing: Private Listing
Part fits (you may select multiples): CRX & pre '92 Civic
Item Condition: MN
I've got bunch of extra 53-56 Ford truck body parts that I'm not going to use and are just taking up way too much space having to store all of it.
All the parts are rougher then they look in the pictures but I feel they are still well worth fixing to use. If you want more pictures of a certain part just let me know.
I would prefer not to ship the larger parts. But I would be willing to ship the air deflectors, short running boards, radiator mount/core support.
I'm located in southern Minnesota about a half hour south of the twin Cities.
If you feel the prices are too high feel free to make on offer. The worse I can say is no.
If you buy all the below at one time I'd sell it all for $700.00.
Front Fenders:
Green ones - They are pretty solid, a couple small spots rusted thru each. But they both do have damage that will need repairing. The driver side is worse damage then the passenger side.
I'm asking $150.00 for the pair.
The Flamed Fenders are straighter but have quite a bit more rust along with a little damage/filler. I'm asking $100.00 pair for these.
Rear Fenders: The rear fenders are in pretty good shape. There are rusted on the lower front section of each fender. They had some poor repairs done to these areas in the past. They welded a piece of sheet metal on the back side of the holes and filled the area with filler. I removed most of the filler so you'd be able to see what repairs will need to be done. I'm asking $200 for the pair.
These also had a big wrap around rear bumper bolted on the lower rear sections. So each fender has one hole drilled in it that will need to be welded closed. There may also be some minor damage in these areas. And the passenger side also has two small holes rusted thru in the bottom. See the third pic down, I circled them.
The mounting flanges are solid. They each have one small rust hole in them. And they may have a spot or two in the flange that could use a little hammer and dolly work.
Front Inner Fenders:
The first pair came out of a solid 55 from South Dakota. I bought the front clip from a guy. They would have been real nice. But the guy I bought them from torched the rear mounting bolts off. So the rear mounting holes need repair. And the upper flanges have a couple areas that need to be flatten out. The passenger side still has the stock voltage regulator.
I'm asking $85.00 for the pair.
The driver side panel has a small crack in the bottom and a rust hole starting on the top rear section of the upper mounting flange.
The second pair of inner fenders is out of a 54 F100 They are in decent shape. They both have the rust on the rear of the upper mounting flange. And there are some spots in the upper flange that will need to be straightened out. I'm asking $75.00 for this pair.
The passenger side panel has a small crack at the rear of the panel. And one of the mounting holes for the stock voltage regulator has some damage.
Up next is a 1955 front valance/gravel pan. It is very solid but does have some minor damage. The bottom edges are bent up in a couple spots. This caused some bending in a rear brace or two. And there is also a dent in one of the frame cut outs. There is also one small crack on the one edge ( circled in the pic below ) . And one very small hole drilled in it.
I'm asking $85.00 for it.
Front Air Deflectors:
I've got 5 air deflectors.
The first pair is off a 54 F100. They are in pretty good shape. The passenger side has one spot rusted thru ( see area circled in one pic below ) . Otherwise They may need to be straightened out in an area or two.
I'm asking $40.00 for the pair.
The next one is a single driver side. I was told it was a 55 but it looks identical to the 54 ones. It is nice and straight. The only issue I see is it looks like some one tried to flatten out the top bulge in the radiator opening area ( for the cross braces ) . I have no idea why they did this.
I'm asking $25.00 for this one.
The last pair are the ones that came on my 54 when I bought it. I believe they are 53 parts. These are in rough shape. They are solid but beat up & butchered. They have a lot of bends/creases in them. There are holes behind the headlight areas ( for a 56 grille ) . They look like they were cut out by a angry beaver. There is also extra hole holes drilled in them for mounting the 56 grille.
I'm asking $25.00 for the pair.
I've got 2 Hood latch/upper valance panels. They both include include the hood and safety latches( as shown in the pictures ).
I'm asking $50.00 each.
The first one is out of a 54 F100.
It may need a little massaging on the end where it meets the fenders. And it doesn't have the seal on the top edge.
The second one is out of a 55. It has the seal but it needs replacing.
I've got one radiator mount/core support out of a 55. It is in good condition except the guy I bought it from cut the two mounting studs off.
I'm asking $50.00.
I've got a very solid pair of 54 F100 short box running boards. They aren't rusty but have quite a bit of damaged that needs to be repaired. The driver side running board has one mounting hole that has some damage. The rest of the holes appear good.
I've got a pair of short running boards. I don't remember what year truck they came off from. I think it may have been a 56 F600. The guy I got them from used a cutting torch on the bolts. So the mounting holes are messed up. They also need some rust repair.
I'm asking $50.00 for the pair.
Old 06-15-2016, 07:49 PM
fordman75's Avatar
fordman75
Bttt.
Old 06-15-2016, 08:03 PM
fordman75's Avatar
fordman75
Bttt.
Old 06-21-2016, 01:01 AM
fordman75's Avatar
fordman75
BTTT. Prices reduced.
Old 06-26-2016, 02:42 AM
56exp's Avatar
56exp
56exp is offline
Would you take $65 for the valance?? Dean
Old 06-26-2016, 02:52 AM
fordman75's Avatar
fordman75
Yes I would. But that price would not include shipping cost. And shipping would not be cheap!
Old 06-28-2016, 06:49 AM
56exp's Avatar
56exp
56exp is offline
I read on here fastenal or greyhound are more reasonable. Do you have either. near you. My valance is shot . can you get shipping estimates? I will be out of service for a couple weeks but I will get back..
Old 06-28-2016, 02:07 PM
fordman75's Avatar
fordman75
Greyhound is not an option for me. I have no clue about fastenal. I would have to do some research on that.
If you want a shipping quote I will need your zip code.
Old 06-29-2016, 01:58 AM
56exp's Avatar
56exp
56exp is offline
12972 who do you normally use?
Old 06-29-2016, 05:34 PM
fordman75's Avatar
fordman75
Most of the stuff I ship is thru USPS. But certain items, like this one would be shipped by UPS.
And it looks like it would cost around $61.00 to ship it by UPS ground.
I did some searching on Fastenal and it looks like it would require pallets and a wood crate. They won't insure it if it's not in a sturdy wood crate. So I would have to charge extra for building the crate. It would end up costing more then UPS ground.
Old 07-12-2016, 03:55 PM
fordman75's Avatar
fordman75
Bttt. All the parts are still for sale.
Old 08-04-2016, 10:02 PM
fordman75's Avatar
fordman75
The air deflectors have been listed on epay. Everything else is still available.
Old 12-26-2016, 09:12 PM
bzerk56's Avatar
bzerk56
bzerk56 is offline
would you be willing to sell and ship a upper latch valance to california ?
Old 12-27-2016, 12:48 AM
fordman75's Avatar
fordman75
I sold the 54 panels. I still have the 55 panel. But no I don't really want to deal with shipping it. It's way too expensive and too much hassle.
Wmrdalydvm
22
01-07-2017 06:46 AM
jrockdiddy
16
10-30-2013 03:14 PM
gregstith
16
06-14-2013 10:30 AM
sled250
08-16-2011 05:35 AM
jmadsen
05-05-2008 08:48 AM
Quick Reply: 53-56 Ford Body parts ( Prices Reduced )
