6.0 turbo and head
Old 06-12-2016, 07:28 PM
Aune163rd's Avatar
Aune163rd
Aune163rd is offline
6.0 turbo and head
I want to do some tinkering on my truck. What's the stock 55mm turbo capable of safely without putting head studs into it. I don't want to be doing head gaskets any time soon. I've got a torn CAC boot and I'm losing serious boost. I'm maxing out at 21 lbs. Any recommendations for this? I've seen metal CAC boots but I have not messed with an intercooled engine.....ever. I've done non intercooled engines do any advice would be great.
Old 06-12-2016, 07:42 PM
MisterCMK's Avatar
MisterCMK
MisterCMK is offline
You should be making 28psi or so. Replace the torn CAC boot.
Old 06-12-2016, 07:43 PM
Aune163rd's Avatar
Aune163rd
I got REALLY oily cac boots.....like really oily. What else is wrong?
Old 06-12-2016, 07:45 PM
Aune163rd's Avatar
Aune163rd
Also. I'm getting a LOT of turbo lag. Takes about 5 seconds to really spool up.
Old 06-12-2016, 07:54 PM
robs97z28's Avatar
robs97z28
robs97z28 is offline
Old 06-12-2016, 08:14 PM
Aune163rd's Avatar
Aune163rd
So besides the torn cac boot. Is anything else gonna cause me to lose 7psi? The tear is a small one. Maybe 1/2 inch long.
Old 06-12-2016, 08:23 PM
Per4mance's Avatar
Per4mance
Per4mance is offline
Thats enough to lose 7 psi,trust me.Sounds like you need to call RiffRaff.
Old 06-12-2016, 08:25 PM
MisterCMK's Avatar
MisterCMK
You could have a sticky turbo, leaks in the up pipes or a combo of the two as well.
Old 06-12-2016, 08:29 PM
Aune163rd's Avatar
Aune163rd
Besides ripping apart the engine. What else can I do to clean up a sticky turbo?
Old 06-12-2016, 09:25 PM
MisterCMK's Avatar
MisterCMK
Pull the turbo and take it apart. Clean up the unison ring, vanes, center section and put it back together.
Old 06-12-2016, 09:31 PM
darrellbarnes's Avatar
darrellbarnes
darrellbarnes is offline
Is the EGR deleted? Haven't got much over 20 PSI since I did the delete.
Aune163rd's Avatar
Aune163rd
How long does it take to pull it? I don't want to end up spending money where I don't need to. Ate there seams and such I have to replace?
Old 06-12-2016, 09:32 PM
Aune163rd's Avatar
Aune163rd
My EGR is deleted but I was getting the same numbers before.
Old 06-12-2016, 09:50 PM
MisterCMK's Avatar
MisterCMK
It doesn't take long. It's quick if the v band clamps have been turned the right way.
Pulling the alternator makes it easier to get the turbo out but it isn't necessary.
Old 06-12-2016, 09:54 PM
Aune163rd's Avatar
Aune163rd
What's the turn around time. I can not afford for it to be down for more than a few hours. It's my SD and I drive bout 3k miles/month.
Quick Reply: 6.0 turbo and head
