3.0L Fast idle and low rpm stall
Have a 1994 Mazda B-3000 truck w/ 3.0L V-6, 5-speed, EEC-IV. Truck starts right off when cold but wants to idle smoothly at 1500 - 1800 rpm even after it warms up. Initial push/snap of throttle to take off (or just to rev engine in neutral) results in a near-stall of engine and I have to let up on gas and try again to get enough revs to take off. Throttle response and acceleration during high-speed operation on road is fine. If I park and shut engine off, it will turn over fine but not start (not even a lick) until it gets completely cold. Have checked vacuum lines, PCV, throttle linkage, and air filter/intake -- all looks fine. Have unhooked IAC solenoid during the fast warm idle and engine slowed down to about 800 - 900 rpm and continued to run smoothly -- but near-stall throttle response remained. Any suggestions?
Thanks for your quick reply! Double checked every vacuum line and fitting I could find and they all look okay. I did a KOEO test with the check engine light and got a single on-demand code of 116 followed by a code of 111 for the continuous memory codes. The 116 (according to haynes) is a "coolant temperature sensor out of self test range" and the 111 is a "pass".
When I start the engine cold, it cranks right up and has no lag/stall when I snap the throttle -- and it runs evenly and powerfully. As it warms up (and I verify with the temp gauge and hot radiator hoses) it exhibits the lag/stall when I snap the throttle and will not restart when I shut the engine down. The engine will restart when it has cooled completely off.
As haynes suggests, I'll pull the connector to the sensor and check the connector/wires. If that doesn't work, then they suggest replacing the sensor. Am I on the right track? Will a faulty coolant temp sensor cause these symptoms?
Thanks again...
Thanks again...
The code 116 was the trick. Got a new coolant temp. sensor for $15 and put it in while i had the negative battery terminal disconnected. Waited a while, reattached the battery, cranked up and the engine runs like a top, low to high rpm, with no stall/lag when i snap the throttle. Engine starts immediately and runs smoothly, cold or hot. Not bad for 141,000 miles. Thanks again...
drpepperinacan
01-22-2012 10:14 PM
LARIAT 85
20
11-10-2011 07:11 PM
rs-mn
1983 - 2012 Ranger & B-Series
08-26-2011 08:48 PM
